Ga door naar hoofdinhoud
Verizon Ellipsis 10 Speaker Replacement
Wat je nodig hebt
  1. Verizon Ellipsis 10 Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Speaker Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Speaker Replacement: stap 9, afbeelding 1 van 1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Speaker Replacement, Speaker: stap 10, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the four M1.5 screws from the right speaker.
  11. Verizon Ellipsis 10 Speaker Replacement: stap 11, afbeelding 1 van 1
    • Remove the black and white wires connected to the motherboard by pulling up on their connections.
    • Remove the three strips of tape.
  12. Verizon Ellipsis 10 Speaker Replacement: stap 12, afbeelding 1 van 1
    • Remove the four M1.5 screws on the left speaker.
    • Remove the speakers from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 143
