Ga door naar hoofdinhoud
Verizon Ellipsis 10 Headphone Jack Replacement
Wat je nodig hebt
  1. Verizon Ellipsis 10 Headphone Jack Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Headphone Jack Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Headphone Jack Replacement: stap 6, afbeelding 1 van 1
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Headphone Jack Replacement: stap 8, afbeelding 1 van 1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Headphone Jack Replacement: stap 9, afbeelding 1 van 1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Headphone Jack Replacement, Headphone Jack: stap 10, afbeelding 1 van 1
    • Locate headphone jack and volume buttons.
  11. Verizon Ellipsis 10 Headphone Jack Replacement: stap 11, afbeelding 1 van 1
    • Pull out the blue/white connector from the circuit board.
  12. Verizon Ellipsis 10 Headphone Jack Replacement: stap 12, afbeelding 1 van 1
    • Gently disconnect the red/black wire from circuit board using a pair of tweezers.
  13. Verizon Ellipsis 10 Headphone Jack Replacement: stap 13, afbeelding 1 van 1
    • Remove all three M1.5 screws with a Phillips #00 screwdriver.
  14. Verizon Ellipsis 10 Headphone Jack Replacement: stap 14, afbeelding 1 van 1
    • Pull out the circuit board.
    • Be careful not to lose the button covers, as there is nothing holding them in the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 185
