Inleiding
In this guide, you will learn how to remove and install the volume wheel of your alarm clock. The process consists of removing the front screen, followed by taking the hardware out of the housing and detaching the power cord. The following step consists of removing the top plastic from the motherboard, being sure to not fully remove the two.
Wat je nodig hebt
On the bottom of the clock locate and unscrew the single 2mm Phillips screw from bottom of the clock.
Get a firm grip on the outside of the clock and a firm grip on the hardware on the inside of the the clock like so and pull the hardware out from the outside of the clock.
Just as before, pull the speaker plug directly up to remove the plug from the motherboard.
