Ga door naar hoofdinhoud
Vent Panel Disassembly
Wat je nodig hebt
  1. Vent Panel Disassembly, Remove Service Panel Screws: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
    • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
  2. Vent Panel Disassembly, Dislodge Service Panel: stap 2, afbeelding 1 van 3 Vent Panel Disassembly, Dislodge Service Panel: stap 2, afbeelding 2 van 3 Vent Panel Disassembly, Dislodge Service Panel: stap 2, afbeelding 3 van 3
    • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
    • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
  3. Vent Panel Disassembly, Remove screw covers: stap 3, afbeelding 1 van 1
    • Remove the four screw covers and place them upside down on a clean surface for later application during reassembly.
  4. Vent Panel Disassembly, Unfasten vent panel: stap 4, afbeelding 1 van 2 Vent Panel Disassembly, Unfasten vent panel: stap 4, afbeelding 2 van 2
    • Unscrew the four T4 Torx screws revealed beneath the rubber feet.
    • Grab Pro Data around the vent panel to prevent it from dropping, and flip the chassis right side up.
  5. Vent Panel Disassembly, Remove vent panel: stap 5, afbeelding 1 van 2 Vent Panel Disassembly, Remove vent panel: stap 5, afbeelding 2 van 2
    • Remove the vent panel by lifting directly up to dislodge it from the brace.
Conclusie
iodyne
432 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 233
