Ga door naar hoofdinhoud
Velocity NoteMagix M10 A82 Hard Drive Replacement
Wat je nodig hebt
  1. Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Velocity NoteMagix M10 A82 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 2 Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 2
    • Unscrew the two 3.65mm Phillips #1 screws on the plate marked "HDD".
  4. Velocity NoteMagix M10 A82 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Lift the HDD plate off of the back to reveal the hard drive.
  5. Velocity NoteMagix M10 A82 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Velocity NoteMagix M10 A82 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Use the spudger to push the area above the connector on the hard drive to the right.
    • Lift the hard drive gently from the computer with the spudger.
Conclusie
Sam Middleton
401 Reputatie
4 handleidingen geschreven
Cal Poly, Team 14-9, Forte Fall 2013 Lid van Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 302
