Inleiding
This guide will show how to safely remove the cooling fan from the NoteMagix M10 A82 netbook.
This will involve removing several parts of the computer using two sizes of screwdrivers and a plastic opening tool. This guide can be easily completed in under one hour.
Wat je nodig hebt
Place the notebook on the table, with the battery facing away from you.
Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
Maintain holding the right switch in the "unlock" position.
Use your left hand to slide the left switch from "lock" to "unlock".
Place the laptop fully opened with the keyboard facing upwards.
Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
