Inleiding
The Velocity Micro Cruz T301 is a tablet that is specifically designed as a multimedia device. The speaker is necessary for all audio based media. As such, it can be a vital part of the user’s experience.
This guide will show you the steps to remove the speaker on a tablet. Once the speaker is removed follow the guide in reverse to install a new speaker.
Wat je nodig hebt
Insert an opening tool in the SD port, with the edge pointing towards the rear panel.
Use the opening tool to pry the back plate up.
