Ga door naar hoofdinhoud
Velocity Micro Cruz T301 Motherboard Replacement
Wat je nodig hebt
  1. Velocity Micro Cruz T301 Motherboard  Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Insert the plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
  2. Velocity Micro Cruz T301 Motherboard  Replacement: stap 2, afbeelding 1 van 1
    • Insert a small opening tool between the rear panel and the tablet.
  3. Velocity Micro Cruz T301 Motherboard  Replacement: stap 3, afbeelding 1 van 1
    • The large opening tool is not needed any more.
  4. Velocity Micro Cruz T301 Motherboard  Replacement: stap 4, afbeelding 1 van 2 Velocity Micro Cruz T301 Motherboard  Replacement: stap 4, afbeelding 2 van 2
    • Move the small tool opener around the rear panel to free the 12 edges.
  5. Velocity Micro Cruz T301 Motherboard  Replacement: stap 5, afbeelding 1 van 1
    • Using PH0 Phillips Driver, remove the 4 Screws in the Metal part.
  6. Velocity Micro Cruz T301 Motherboard  Replacement: stap 6, afbeelding 1 van 1
    • Using a plastic Spudger remove the battery connector.
  7. Velocity Micro Cruz T301 Motherboard  Replacement: stap 7, afbeelding 1 van 1
    • Using PH0 Phillips Driver, remove the 12 Screws in the cover.
  8. Velocity Micro Cruz T301 Motherboard  Replacement: stap 8, afbeelding 1 van 1
    • Place a metal Spudger between the tablet and the back cover.
  9. Velocity Micro Cruz T301 Motherboard  Replacement: stap 9, afbeelding 1 van 1
    • Move the spudger around the tablet to release the clips attached to the tablet.
  10. Velocity Micro Cruz T301 Motherboard  Replacement: stap 10, afbeelding 1 van 1
    • Use a plastic spudger to release the connection between the speakers and the motherboard as shown in the picture.
  11. Velocity Micro Cruz T301 Motherboard  Replacement: stap 11, afbeelding 1 van 1
    • This guide shows the use of incorrect tools. Always use ESD safe tools when dealing with delicate internal components.
    • Use a nylon spudger to remove the top plug connector from the motherboard.
  12. Velocity Micro Cruz T301 Motherboard  Replacement: stap 12, afbeelding 1 van 2 Velocity Micro Cruz T301 Motherboard  Replacement: stap 12, afbeelding 2 van 2
    • Use a metal spudger to remove both screen cable connectors
  13. Velocity Micro Cruz T301 Motherboard  Replacement: stap 13, afbeelding 1 van 1
    • use openning tools to remove the motherboard.
Conclusie
Ahmed
227 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-6, Cagle Fall 2016 Lid van USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 183
