Ga door naar hoofdinhoud
Velocity Micro Cruz Battery Replacement
Wat je nodig hebt
  1. Velocity Micro Cruz Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert a plastic opening device into the small crack separating the screen and the back of the device.
    • After the back of the device is separated, remove the back and you can now access the battery.
    • When prying the back of the device off, be careful as this could cause small damages or cracks to the screen.
  2. Velocity Micro Cruz Battery Replacement: stap 2, afbeelding 1 van 1
    • The battery is connected to the motherboard where the picture indicates.
    • To remove the battery, you must first detach the battery wire connecting it from the motherboard. To do this, simply gently, but firmly, pull it out of the motherboard connector.
  3. Velocity Micro Cruz Battery Replacement: stap 3, afbeelding 1 van 1
    • Simply pry the battery out of the device at this point. The battery may be held in place by adhesive glue and require a nylon spudger or plastic opening tool to help pry it out.
    • Place your new battery in place of the old one. Connect the new battery's wire to the motherboard and you are finished.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hunter Ralston
122 Reputatie
1 Handleiding geschreven
Texas Tech, Team 12-4, Bennett Fall 2016 Lid van Texas Tech, Team 12-4, Bennett Fall 2016
TTU-BENNETT-F16S12G4
4 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 1,072
