Velbon CX690 Tripod Mounting Plate Cap Replacement
Inleiding
This short but in-depth guide will walk you through the process of replacing a displaced mounting plate cap on the Velbon CX690 Tripod. You will need a welding solution, such as JB Weld, in order to complete this project.
Grab the side-tilt-locking-nut with your dominant hand and grab the pan handle with your other hand. Twist the side-tilt-locking-nut counterclockwise to loosen it, and then pull it off.
Grab the pan handle with your dominant hand and grab the quick-release plate with the other. Twist the pan handle counterclockwise until loose and then pull it off of the quick-release plate.
Grab the pan head of the quick-release plate with your dominant hand and the other part of the quick-release plate with your other hand. Then, rotate the pan head clockwise 90 degrees.
Insert the pan handle back into its original hole. Rotate the pan handle clockwise. Make sure the washer is still connected and tighten until it feels tight.
Do not use excessive force when tightening the pan handle.
