Ga door naar hoofdinhoud
Inleiding
This guide will teach the user how to replace the fan.
  1. Flip laptop over so that "Service TAG" is shown at the top left corner.
    • Flip laptop over so that "Service TAG" is shown at the top left corner.
  2. Remove highlighted screws from back of laptop.
    • Remove highlighted screws from back of laptop.
  3. Remove screws from panels at bottom right hand side.
    • Remove screws from panels at bottom right hand side.
  4. Remove two panels at bottom right hand corner by sliding in direction of arrows shown
    • Remove two panels at bottom right hand corner by sliding in direction of arrows shown
  5. Remove screws underneath removed panels.
    • Remove screws underneath removed panels.
  6. Remove Hard drive from computer.
    • Remove Hard drive from computer.
  7. Remove battery by pressing inwards on both tabs.
    • Remove battery by pressing inwards on both tabs.
  8. Remove cover at top left of laptop by pulling outwards.
    • Remove cover at top left of laptop by pulling outwards.
  9. Remove backplate of laptop by pulling outward.
    • Remove backplate of laptop by pulling outward.
  10. Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out. Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out. Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out.
    • Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out.
  11. Unscrew the four screws which hold in the fan. Unscrew the four screws which hold in the fan.
    • Unscrew the four screws which hold in the fan.
  12. Lift out the fan and place it to the side. DO NOT FORCEFULLY PULL THE FAN AWAY there is still a wire attaching it to the circuit board and you don't want to damage the circuit board.
    • Lift out the fan and place it to the side.
    • DO NOT FORCEFULLY PULL THE FAN AWAY there is still a wire attaching it to the circuit board and you don't want to damage the circuit board.
  13. Remove the connection by gently pull the remaining connection up from where it is attached. Remove the connection by gently pull the remaining connection up from where it is attached.
    • Remove the connection by gently pull the remaining connection up from where it is attached.
  14. Replace the old fan with the new one.
    • Replace the old fan with the new one.
    • Make sure that fan being used to replace is compatible with computer.
    • Sony no-longer has a list of compatible fans, so this may be difficult if not impossible.
    • Another option to making it quieter it is to blow off the accumulated dust either by blowing on it, or more effectively by using an air hose.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Geoffrey
252 Reputatie
2 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 233
