Inleiding
If the brush roll on your Bissell Vacuum 2610E is worn out and isn't cleaning as well as it used to, it might be time to replace the brush. This quick guide will show how you how to replace the brush roll with nothing more than a Phillips #0 screwdriver and about 20 minutes of your time.
Wat je nodig hebt
Lay the vacuum flat on the ground, then use a sturdy object to prop up the bottom.
Één andere persoon heeft deze handleiding voltooid.
