Ga door naar hoofdinhoud
VTech VM3254 Camera Speaker Replacement
Wat je nodig hebt
  1. VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: stap 1, afbeelding 1 van 3 VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: stap 1, afbeelding 2 van 3 VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: stap 1, afbeelding 3 van 3
    • Remove the two 8 mm Phillips #00 screws from the back of the device.
    • Use the Jimmy tool to open the case.
    • You may need to use an opening pick to hold it open.
    • Remove the face from the case.
  2. VTech VM3254 Camera Speaker Replacement: stap 2, afbeelding 1 van 2 VTech VM3254 Camera Speaker Replacement: stap 2, afbeelding 2 van 2
    • Remove the three 8 mm Phillips #00 screws from the board.
    • Gently remove the board from the case.
    • Be careful, there are wires connecting the board to the case that could be damaged.
  3. VTech VM3254 Camera Speaker Replacement, Camera Speaker: stap 3, afbeelding 1 van 3 VTech VM3254 Camera Speaker Replacement, Camera Speaker: stap 3, afbeelding 2 van 3 VTech VM3254 Camera Speaker Replacement, Camera Speaker: stap 3, afbeelding 3 van 3
    • Unscrew and remove the two 7 mm Phillips #0 screws that secure the speaker.
    • Remove the speaker.
    • Desolder the speakers cords from the motherboard.
Conclusie
Christina Block
375 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 192
