Ga door naar hoofdinhoud
VTech Safe And Sound DM221 Speaker Replacement
Wat je nodig hebt
  1. VTech Safe And Sound DM221 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Remove the battery cover.
  2. VTech Safe And Sound DM221 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Unplug the battery from its connector and remove.
  3. VTech Safe And Sound DM221 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
  4. VTech Safe And Sound DM221 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Separate the back half of the device from the front using the metal spudger.
  5. VTech Safe And Sound DM221 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
    • This will allow the removal of the silver handle.
  6. VTech Safe And Sound DM221 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove the “TALK” button to get access to remove the motherboard.
  7. VTech Safe And Sound DM221 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Push down on the antenna, located on the top of the motherboard.
  8. VTech Safe And Sound DM221 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Gently remove the motherboard away from the monitor.
    • Be careful not to disconnect the red wire.
  9. VTech Safe And Sound DM221 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
Conclusie
Krystal
600 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-5, Leahy Fall 2015 Lid van USF Tampa, Team 1-5, Leahy Fall 2015
USFT-LEAHY-F15S1G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 337
