Ga door naar hoofdinhoud
VTech Learning Tunes Karaoke Mode Selector Replacement
Wat je nodig hebt
  1. VTech Learning Tunes Karaoke Mode Selector Replacement, Mode Selector: stap 1, afbeelding 1 van 1
    • To remove the battery door, loosen the 4mm Flathead screw.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Mode Selector Replacement: stap 2, afbeelding 1 van 2 VTech Learning Tunes Karaoke Mode Selector Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Mode Selector Replacement: stap 3, afbeelding 1 van 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Mode Selector Replacement: stap 4, afbeelding 1 van 2 VTech Learning Tunes Karaoke Mode Selector Replacement: stap 4, afbeelding 2 van 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Mode Selector Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 7.9 mm Phillips #1 mode switch board screws.
  6. VTech Learning Tunes Karaoke Mode Selector Replacement: stap 6, afbeelding 1 van 2 VTech Learning Tunes Karaoke Mode Selector Replacement: stap 6, afbeelding 2 van 2
    • Once the screws have been removed, carefully move the mode switch board to expose the mode switch assembly underneath.
  7. VTech Learning Tunes Karaoke Mode Selector Replacement: stap 7, afbeelding 1 van 2 VTech Learning Tunes Karaoke Mode Selector Replacement: stap 7, afbeelding 2 van 2
    • Using a Philips #1 screwdriver, remove the two 5.6 mm screws on the switch.
    • Once the screws have been removed, you can easily remove the mode switch.
Conclusie
Adam Chaberek
137 Reputatie
1 Handleiding geschreven
USF Tampa, Team 7-2, Cheng Spring 2016 Lid van USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 337
