Ga door naar hoofdinhoud
VTech Kidizoom Smartwatch DX2 Wristband Replacement
Wat je nodig hebt
  1. VTech Kidizoom Smartwatch DX2 Wristband Replacement, Wristband: stap 1, afbeelding 1 van 1
    • Begin by placing the watch on its side.
  2. VTech Kidizoom Smartwatch DX2 Wristband Replacement: stap 2, afbeelding 1 van 1
    • Next, use the flat end of the spudger to wedge between the small-headed pin (located on the band closest to the watch) to pull the pin up through the other side.
  3. VTech Kidizoom Smartwatch DX2 Wristband Replacement: stap 3, afbeelding 1 van 1
    • Pull the pin out, however not fully, feeling slight resistance is normal.
  4. VTech Kidizoom Smartwatch DX2 Wristband Replacement: stap 4, afbeelding 1 van 1
    • Finally, pull the wristband off. Repeat on the opposite side of the watch if necessary.
Conclusie
Sydney
344 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
4 Leden
7 handleidingen geschreven
Één opmerking
My Vtech DX2 had a split pin. One side of the pin was the long side and the other very very short. So look out for that. Thanks for this tutorial, was very helpful.
Ryan Laurel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 50
Altijd: 7,251
