Ga door naar hoofdinhoud
VTech Kidizoom Smartwatch DX2 Faceplate Replacement
Wat je nodig hebt
  1. VTech Kidizoom Smartwatch DX2 Faceplate Replacement, Faceplate: stap 1, afbeelding 1 van 1
    • In order to remove the faceplate you must start by placing the watch screen upwards.
  2. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: stap 2, afbeelding 1 van 1
    • Use iFixit’s opening tool, another similar tool, or simply use your fingernail to gently pry open the faceplate away from the screen starting from an edge.
    • You may hear a popping sound, but this is normal.
  3. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: stap 3, afbeelding 1 van 1
    • Once successful, pull the remaining faceplate off from the watch.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jessica Richard
512 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
4 Leden
7 handleidingen geschreven
4 opmerkingen
Where can I find a faceplate?
Sammi Schummer - Antwoord
Where can you buy a replacement face plate?
Natalie - Antwoord
This doesn't remove the faceplate, just the decorative bezel around the screen. I'm looking for disassembly instructions to open up the screen as my son wore his I to the pool (immediately after being told not to! Kids…)
Jack Wesselo - Antwoord
Where can I get a replacement faceplate please
Steph Crowe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 20
Altijd: 2,536
