Ga door naar hoofdinhoud
VTech Kidizoom Smartwatch DX2 Battery Replacement
Wat je nodig hebt
  1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: stap 1, afbeelding 1 van 2 VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: stap 1, afbeelding 2 van 2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 2, afbeelding 1 van 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 2, afbeelding 2 van 2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 3, afbeelding 1 van 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 3, afbeelding 2 van 2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 4, afbeelding 1 van 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 4, afbeelding 2 van 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 4, afbeelding 3 van 3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Battery Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 6, afbeelding 1 van 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 6, afbeelding 2 van 2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 7, afbeelding 1 van 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 7, afbeelding 2 van 2
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Battery Replacement, Battery: stap 8, afbeelding 1 van 1
    • Carefully pry the battery off of the circuit board using the plastic opening tool.
  9. VTech Kidizoom Smartwatch DX2 Battery Replacement: stap 9, afbeelding 1 van 1
    • De-solder the wires connecting the battery to the circuit board.
    • Remove the battery.
Conclusie
Jessica Richard
512 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
4 Leden
7 handleidingen geschreven
4 opmerkingen
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
Gabriel Baker - Antwoord
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 105
Altijd: 9,164
