Ga door naar hoofdinhoud
VTech Kidizoom Camera Connect Front Case Replacement
Wat je nodig hebt
  1. VTech Kidizoom Camera Connect Front Case Replacement, Front Case: stap 1, afbeelding 1 van 2 VTech Kidizoom Camera Connect Front Case Replacement, Front Case: stap 1, afbeelding 2 van 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Front Case Replacement: stap 2, afbeelding 1 van 2 VTech Kidizoom Camera Connect Front Case Replacement: stap 2, afbeelding 2 van 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Front Case Replacement: stap 3, afbeelding 1 van 3 VTech Kidizoom Camera Connect Front Case Replacement: stap 3, afbeelding 2 van 3 VTech Kidizoom Camera Connect Front Case Replacement: stap 3, afbeelding 3 van 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Front Case Replacement: stap 4, afbeelding 1 van 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick Foster
288 Reputatie
1 Handleiding geschreven
USF Tampa, Team 6-4, Eyestone Spring 2016 Lid van USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 43
Altijd: 4,099
