Ga door naar hoofdinhoud
VTech InnoTab 2s Back Panel Replacement
Wat je nodig hebt
  1. VTech InnoTab 2s Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2s Back Panel Replacement: stap 2, afbeelding 1 van 2 VTech InnoTab 2s Back Panel Replacement: stap 2, afbeelding 2 van 2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2s Back Panel Replacement: stap 3, afbeelding 1 van 3 VTech InnoTab 2s Back Panel Replacement: stap 3, afbeelding 2 van 3 VTech InnoTab 2s Back Panel Replacement: stap 3, afbeelding 3 van 3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2s Back Panel Replacement: stap 4, afbeelding 1 van 2 VTech InnoTab 2s Back Panel Replacement: stap 4, afbeelding 2 van 2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2s Back Panel Replacement: stap 5, afbeelding 1 van 2 VTech InnoTab 2s Back Panel Replacement: stap 5, afbeelding 2 van 2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ricardo Espinosa
221 Reputatie
2 handleidingen geschreven
USF Tampa, Team 5-1, Lacy Fall 2016 Lid van USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 257
