Ga door naar hoofdinhoud
VTech Baby's Learning Laptop Speaker Replacement
Wat je nodig hebt
  1. VTech Baby's Learning Laptop Speaker Replacement, Battery and Rear Panel: stap 1, afbeelding 1 van 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Speaker Replacement: stap 4, afbeelding 1 van 2 VTech Baby's Learning Laptop Speaker Replacement: stap 4, afbeelding 2 van 2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Speaker Replacement, Speaker: stap 5, afbeelding 1 van 2 VTech Baby's Learning Laptop Speaker Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to unscrew the two 6.0 mm screws on the speaker.
  6. VTech Baby's Learning Laptop Speaker Replacement: stap 6, afbeelding 1 van 2 VTech Baby's Learning Laptop Speaker Replacement: stap 6, afbeelding 2 van 2
    • Remove the two 6 mm screws from the device.
    • Remove the speaker.
    • Be careful not to damage the wiring.
Conclusie
Jordan Smith
210 Reputatie
2 handleidingen geschreven
USF Tampa, Team 12-2, Blackwell Fall 2015 Lid van USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Leden
14 handleidingen geschreven
2 opmerkingen
Where to buy the replacement speaker
hadbuckley - Antwoord
Where can you buy the replacement speaker please. I live in Sydney Australia
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 1,243
