Inleiding
A snag on a branch. That's all it takes to ruin the sweater grandma knitted for you. Due to the intricacies that is the knitting process, people often feel hopeless when there is a hole in their knitted sweater. The loose strands, the ruined patterned stitches, all of it seems impossible to repair. However, there is still a chance for salvation and this guide here will tell you all about it.
Using needlework and crochet techniques, this repair guide will take you through the steps of repairing holes in knitwear while making it look perfect and brand new again.
Wat je nodig hebt
Thread your desired yarn color through the needle.
In the row next to the hole, insert your needle into the bottom-most stitch from the back to the front, pulling all the way through (Image 2).
Insert your needle into the V-shaped stitch above, going through both loops of the stitch (Image 3).
Re-thread your needle.
In the stitch above your starting stitch (from steps 1 and 2), insert your needle from back to front, pulling all the way through (Image 1).
Insert your needle into the V-shaped stitch above, going through both loops of the stitch (Image 2).
Insert your needle back into the stitch below, pulling all the way through.
Cut your thread (same length as the first cut).
