Ga door naar hoofdinhoud
Untracked Bifold Door Pin Replacement
Wat je nodig hebt
  1. Untracked Bifold Door Pin Replacement, Bifold Door Pin: stap 1, afbeelding 1 van 1
    • Stand on a small ladder or step stool to get a better view of the top of the door.
  2. Untracked Bifold Door Pin Replacement: stap 2, afbeelding 1 van 1
    • Locate the pin at the top of the door.
  3. Untracked Bifold Door Pin Replacement: stap 3, afbeelding 1 van 1
    • Remove the current pin with pliers.
  4. Untracked Bifold Door Pin Replacement: stap 4, afbeelding 1 van 2 Untracked Bifold Door Pin Replacement: stap 4, afbeelding 2 van 2
    • Clean the top of the door using cleaning spray and a rag. This will help remove any dust or wood fragments left behind.
    • I used Meyer's spray, but any household cleaning spray will work just fine.
  5. Untracked Bifold Door Pin Replacement: stap 5, afbeelding 1 van 1
    • Replace old pin with new pin using the pliers to place into the hole at the top of the door.
    • You can purchase a new pin at either Ace Hardware or Home Depot.
  6. Untracked Bifold Door Pin Replacement: stap 6, afbeelding 1 van 1
    • Push the pin all the way in by using a hammer.
    • No excessive force is needed. Gently tap the pin with the hammer until it is secured.
  7. Untracked Bifold Door Pin Replacement: stap 7, afbeelding 1 van 1
    • Line up the newly placed pin with the door's tracking.
    • Push the door down slightly and then lift it back up to align it with the track.
  8. Untracked Bifold Door Pin Replacement: stap 8, afbeelding 1 van 1
    • Secure the pin within the tracking using the pliers.
  9. Untracked Bifold Door Pin Replacement: stap 9, afbeelding 1 van 1
    • When completed, the bifold doors should close and be positioned within the tracking.
Conclusie
Catelyn Carpenter
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 45
Altijd: 1,348
