Ga door naar hoofdinhoud
Unsticking SteelSeries Nimbus Triggers
Wat je nodig hebt
  1. Unsticking SteelSeries Nimbus Triggers, Unsticking SteelSeries Nimbus Triggers: stap 1, afbeelding 1 van 1
    • When your triggers get stickier than the Cheeto® dust on your hands it might be time for an intervention.
  2. Unsticking SteelSeries Nimbus Triggers: stap 2, afbeelding 1 van 2 Unsticking SteelSeries Nimbus Triggers: stap 2, afbeelding 2 van 2
    • Start off by removing the four TR9 Torx Security screws on the back of the controller.
  3. Unsticking SteelSeries Nimbus Triggers: stap 3, afbeelding 1 van 3 Unsticking SteelSeries Nimbus Triggers: stap 3, afbeelding 2 van 3 Unsticking SteelSeries Nimbus Triggers: stap 3, afbeelding 3 van 3
    • The two screws on the top are further inset than the others. You can use the iFixit 1/4" to 4 mm Driver Adapter as an extender.
  4. Unsticking SteelSeries Nimbus Triggers: stap 4, afbeelding 1 van 2 Unsticking SteelSeries Nimbus Triggers: stap 4, afbeelding 2 van 2
    • The case is now open, but it's still held together by two clips on the top.
  5. Unsticking SteelSeries Nimbus Triggers: stap 5, afbeelding 1 van 3 Unsticking SteelSeries Nimbus Triggers: stap 5, afbeelding 2 van 3 Unsticking SteelSeries Nimbus Triggers: stap 5, afbeelding 3 van 3
    • Apply a gentle twisting motion to separate the first clip.
    • Twist in the other direction to separate the second clip.
    • The top is now free!
  6. Unsticking SteelSeries Nimbus Triggers: stap 6, afbeelding 1 van 3 Unsticking SteelSeries Nimbus Triggers: stap 6, afbeelding 2 van 3 Unsticking SteelSeries Nimbus Triggers: stap 6, afbeelding 3 van 3
    • Be mindful of the three cables still connecting the two halves.
  7. Unsticking SteelSeries Nimbus Triggers: stap 7, afbeelding 1 van 2 Unsticking SteelSeries Nimbus Triggers: stap 7, afbeelding 2 van 2
    • Here's our problem, the rubber pad has fallen off of the plastic stop leaving only the glue behind.
    • The rubber pad should still be in the controller somewhere (happy hunting) or if you're not in the mood for hide and seek any kind of foam will work as a replacement.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Jonathan
464 Reputatie
2 handleidingen geschreven
4 opmerkingen
Great, concise fix instructions!
Brian Pippen - Antwoord
My nimbus started to have sticky triggers. I could not believe that I had found this solution! Awesome!
Max-Heinrich Laves - Antwoord
Hi, I have a Nimbus + controller. It's seems to have clips at the back too. Any advice on how to open it?
Sean Hudson - Antwoord
Greetings, someone who can help me where I can get the joystick, original remote control ?
Excellent information
bryan Andino - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 41
Altijd: 6,129
