Ga door naar hoofdinhoud
Uniden UTAB71 Camera Replacement
Wat je nodig hebt
  1. Uniden UTAB71 Camera Replacement, Camera: stap 1, afbeelding 1 van 2 Uniden UTAB71 Camera Replacement, Camera: stap 1, afbeelding 2 van 2
    • Use a plastic pry tool to separate the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Camera Replacement: stap 2, afbeelding 1 van 2 Uniden UTAB71 Camera Replacement: stap 2, afbeelding 2 van 2
    • Use a credit card to lift the battery off the back of the tablet.
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery is glued onto the back of the tablet so make sure to apply as much pressure as needed
  3. Uniden UTAB71 Camera Replacement: stap 3, afbeelding 1 van 1
    • Undo the clips off the power ribbon connecting the camera to the motherboard using the blue pry tool.
  4. Uniden UTAB71 Camera Replacement: stap 4, afbeelding 1 van 3 Uniden UTAB71 Camera Replacement: stap 4, afbeelding 2 van 3 Uniden UTAB71 Camera Replacement: stap 4, afbeelding 3 van 3
    • Use the pry tool to remove the yellow tape from the power ribbon connected to the camera.
    • Place the plastic pry tool under the camera component and lift it off the tablet.
Conclusie
Ryan Jewell
422 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-4, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 167
