Ga door naar hoofdinhoud
Uniden TCX905 Back Speaker Replacement
Wat je nodig hebt
  1. Uniden TCX905 Back Speaker Replacement, Battery Cover: stap 1, afbeelding 1 van 2 Uniden TCX905 Back Speaker Replacement, Battery Cover: stap 1, afbeelding 2 van 2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Back Speaker Replacement, Battery Pack: stap 2, afbeelding 1 van 2 Uniden TCX905 Back Speaker Replacement, Battery Pack: stap 2, afbeelding 2 van 2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Back Speaker Replacement, Back Shell: stap 3, afbeelding 1 van 2 Uniden TCX905 Back Speaker Replacement, Back Shell: stap 3, afbeelding 2 van 2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Back Speaker Replacement: stap 4, afbeelding 1 van 3 Uniden TCX905 Back Speaker Replacement: stap 4, afbeelding 2 van 3 Uniden TCX905 Back Speaker Replacement: stap 4, afbeelding 3 van 3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Back Speaker Replacement: stap 5, afbeelding 1 van 3 Uniden TCX905 Back Speaker Replacement: stap 5, afbeelding 2 van 3 Uniden TCX905 Back Speaker Replacement: stap 5, afbeelding 3 van 3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Back Speaker Replacement, Back Speaker: stap 6, afbeelding 1 van 2 Uniden TCX905 Back Speaker Replacement, Back Speaker: stap 6, afbeelding 2 van 2
    • Lay the back shell with the inside facing up
    • To remove the speaker guard, first remove the 7mm screw from inside the back shell
  7. Uniden TCX905 Back Speaker Replacement: stap 7, afbeelding 1 van 3 Uniden TCX905 Back Speaker Replacement: stap 7, afbeelding 2 van 3 Uniden TCX905 Back Speaker Replacement: stap 7, afbeelding 3 van 3
    • To access the speaker, flip the back shell over and use a plastic opening tool to pop open the black cover
    • Gently push the speaker guard out of place with your thumb
    • Carefully slide the speaker out from its setting and place speaker guard aside
  8. Uniden TCX905 Back Speaker Replacement: stap 8, afbeelding 1 van 2 Uniden TCX905 Back Speaker Replacement: stap 8, afbeelding 2 van 2
    • With speaker exposed, remove the speaker by cutting the red and black wires near their contact location
Conclusie
Gary Pence
807 Reputatie
8 handleidingen geschreven
Clemson, Team 1-1, Benson Spring 2014 Lid van Clemson, Team 1-1, Benson Spring 2014
CLEM-BENSON-S14S1G1
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 313
