Ga door naar hoofdinhoud
Uniden EXP 371 Keypad Replacement
Wat je nodig hebt
  1. Uniden EXP 371 Keypad Replacement, Dissassemble the Uniden EXP 371 phone: stap 1, afbeelding 1 van 1
    • Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
  2. Uniden EXP 371 Keypad Replacement: stap 2, afbeelding 1 van 3 Uniden EXP 371 Keypad Replacement: stap 2, afbeelding 2 van 3 Uniden EXP 371 Keypad Replacement: stap 2, afbeelding 3 van 3
    • Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
  3. Uniden EXP 371 Keypad Replacement: stap 3, afbeelding 1 van 2 Uniden EXP 371 Keypad Replacement: stap 3, afbeelding 2 van 2
    • Remove the motherboard once the screws holding it in place are undone.
    • Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
  4. Uniden EXP 371 Keypad Replacement: stap 4, afbeelding 1 van 1
    • After the rubber pad is removed remove the dial pad (buttons) from the phone.
  5. Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: stap 5, afbeelding 1 van 2 Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: stap 5, afbeelding 2 van 2
    • If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons.
    • Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
  6. Uniden EXP 371 Keypad Replacement, Order a New Dial Pad: stap 6, afbeelding 1 van 1
Conclusie
Lucas Mohsen
101 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Lid van UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 135
