Ga door naar hoofdinhoud
Uniden Dect 6.0 Keyboard Replacement
Wat je nodig hebt
  1. Uniden Dect 6.0 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 Uniden Dect 6.0 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Megan Lawrence
534 Reputatie
5 handleidingen geschreven
Één opmerking
Great to have this guide! I’d add that (at least on my aging handset). Prying it open can feel a bit sketchy cause it may resist a bit, so I used the metal spudger to go around the edge lifting the tabs. But the plastic on these is pretty great and will not break even puting some force on it.
Also be mindful of the speaker on the back which is connected to the front case.
Ivan Viales - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 3,405
