Ga door naar hoofdinhoud
Uniden D1483-3BK Handset Keypad Replacement
Wat je nodig hebt
  1. Uniden D1483-3BK Handset Keypad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Handset Keypad Replacement: stap 2, afbeelding 1 van 2 Uniden D1483-3BK Handset Keypad Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Handset Keypad Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Handset Keypad Replacement, Handset Case: stap 4, afbeelding 1 van 2 Uniden D1483-3BK Handset Keypad Replacement, Handset Case: stap 4, afbeelding 2 van 2
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Handset Keypad Replacement: stap 5, afbeelding 1 van 3 Uniden D1483-3BK Handset Keypad Replacement: stap 5, afbeelding 2 van 3 Uniden D1483-3BK Handset Keypad Replacement: stap 5, afbeelding 3 van 3
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Handset Keypad Replacement: stap 6, afbeelding 1 van 2 Uniden D1483-3BK Handset Keypad Replacement: stap 6, afbeelding 2 van 2
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Handset Keypad Replacement: stap 7, afbeelding 1 van 2 Uniden D1483-3BK Handset Keypad Replacement: stap 7, afbeelding 2 van 2
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Handset Keypad Replacement, Handset Keypad: stap 8, afbeelding 1 van 1
    • Remove the rubber keypad from the front half of the handset case.
    • The keypad comes in two separate pieces.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Arbitrary Name
1.083 Reputatie
4 handleidingen geschreven
Penn State, Team 1-8, Kaschak Winter 2015 Lid van Penn State, Team 1-8, Kaschak Winter 2015
PSU-KASCHAK-W15S1G8
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 213
