Ga door naar hoofdinhoud
Unbranded UB-15MS10 Power Button Replacement
Wat je nodig hebt
  1. Unbranded UB-15MS10 Power Button Replacement, Power Button: stap 1, afbeelding 1 van 3 Unbranded UB-15MS10 Power Button Replacement, Power Button: stap 1, afbeelding 2 van 3 Unbranded UB-15MS10 Power Button Replacement, Power Button: stap 1, afbeelding 3 van 3
    • Use an opening tool to pry off the memory card door located on the back of the tablet.
  2. Unbranded UB-15MS10 Power Button Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 1.2mm screws found under the memory card door.
  3. Unbranded UB-15MS10 Power Button Replacement: stap 3, afbeelding 1 van 3 Unbranded UB-15MS10 Power Button Replacement: stap 3, afbeelding 2 van 3 Unbranded UB-15MS10 Power Button Replacement: stap 3, afbeelding 3 van 3
    • Pry around the outside carefully using the black spudger to get in. Putting many opening tools around the edge helps keep it from sealing shut again.
  4. Unbranded UB-15MS10 Power Button Replacement: stap 4, afbeelding 1 van 2 Unbranded UB-15MS10 Power Button Replacement: stap 4, afbeelding 2 van 2
    • Remove the ribbon cable by using the black spudger to release the tab and carefully pull out the ribbon cable.
  5. Unbranded UB-15MS10 Power Button Replacement: stap 5, afbeelding 1 van 3 Unbranded UB-15MS10 Power Button Replacement: stap 5, afbeelding 2 van 3 Unbranded UB-15MS10 Power Button Replacement: stap 5, afbeelding 3 van 3
    • Peel up the grey tape so that you can get to the board and untape the ribbon cable that was removed from the motherboard in the previous step.
  6. Unbranded UB-15MS10 Power Button Replacement: stap 6, afbeelding 1 van 2 Unbranded UB-15MS10 Power Button Replacement: stap 6, afbeelding 2 van 2
    • Remove the two 1.2mm screws from the board.
  7. Unbranded UB-15MS10 Power Button Replacement: stap 7, afbeelding 1 van 1
    • Use an opening tool to remove the board from the case.
  8. Unbranded UB-15MS10 Power Button Replacement: stap 8, afbeelding 1 van 2 Unbranded UB-15MS10 Power Button Replacement: stap 8, afbeelding 2 van 2
    • Detach the three ribbon cables using spudger in the first picture. Then cut the black, white, and red wires shown in picture two.
  9. Unbranded UB-15MS10 Power Button Replacement: stap 9, afbeelding 1 van 1
    • Check to see if plastic power button is broken. If broken, replace with new plastic power button. Rebuild device by doing steps 1-8 in reverse order and see if your power button is working. If the device still does not turn on, follow steps 1-8 and skip this step.
  10. Unbranded UB-15MS10 Power Button Replacement: stap 10, afbeelding 1 van 1
    • Unscrew the two 1.2mm screws of this component, which is wired to the motherboard.
  11. Unbranded UB-15MS10 Power Button Replacement: stap 11, afbeelding 1 van 1
    • Unscrew the two 1.2mm screws of this component, which is also wired to the motherboard.
  12. Unbranded UB-15MS10 Power Button Replacement: stap 12, afbeelding 1 van 1
    • Remove old motherboard from tablet. Take the new motherboard and splice the black wire of the board to the black wire of the battery. Do the same for the white and red wires.
Conclusie
To reassemble your device, follow steps 1-8 and 10-11 in reverse order.
Matthew Sylvia
280 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 Lid van UMass Dartmouth, Team S5-G5, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G5
3 Leden
4 handleidingen geschreven
Één opmerking
Hello,
Do you have a part for the power button or know of a place that would sell them?
Thanks!
John - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 1,704
