Ga door naar hoofdinhoud
UTStarcom XV6700 Battery Replacement
Wat je nodig hebt
  1. UTStarcom XV6700 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press the on/off button on the top to power the phone off.
  2. UTStarcom XV6700 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery cover by pressing and sliding the cover down and off of the phone.
  3. UTStarcom XV6700 Battery Replacement: stap 3, afbeelding 1 van 3 UTStarcom XV6700 Battery Replacement: stap 3, afbeelding 2 van 3 UTStarcom XV6700 Battery Replacement: stap 3, afbeelding 3 van 3
    • Pull the battery removal tab and lift the battery out of the phone.
    • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
Conclusie
Één opmerking
it wont keep a charge, ive bought new battery and it will turn on load up. at main screen no longer than 10 seconds and shuts off.
jloizos79 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 344
