Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
Identify the antenna. It is the extendable plastic component pictured here.
Twist the base in a counter-clockwise motion to unscrew the antenna.
The antenna should slide right out of the phone when finished.
Remove the small rubber grommet using the plastic opening tool.
Remove five screws using a Phillips #00 screwdriver.
Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
Remove the wire attached to the speaker from the motherboard using tweezers.
Detach the highlighted piece from the logic board using a plastic opening tool.
Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
