Ga door naar hoofdinhoud
Turtle Beach Recon Controller Front Buttons Replacement
Wat je nodig hebt
  1. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: stap 1, afbeelding 1 van 3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: stap 1, afbeelding 2 van 3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: stap 1, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
  2. Turtle Beach Recon Controller Front Buttons Replacement: stap 2, afbeelding 1 van 3 Turtle Beach Recon Controller Front Buttons Replacement: stap 2, afbeelding 2 van 3 Turtle Beach Recon Controller Front Buttons Replacement: stap 2, afbeelding 3 van 3
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
  3. Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: stap 3, afbeelding 1 van 2 Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: stap 3, afbeelding 2 van 2
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
  4. Turtle Beach Recon Controller Front Buttons Replacement: stap 4, afbeelding 1 van 2 Turtle Beach Recon Controller Front Buttons Replacement: stap 4, afbeelding 2 van 2
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
  5. Turtle Beach Recon Controller Front Buttons Replacement: stap 5, afbeelding 1 van 3 Turtle Beach Recon Controller Front Buttons Replacement: stap 5, afbeelding 2 van 3 Turtle Beach Recon Controller Front Buttons Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
  6. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: stap 6, afbeelding 1 van 3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: stap 6, afbeelding 2 van 3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: stap 6, afbeelding 3 van 3
    • Gently remove front buttons from the face plate by hand.
Conclusie
Mary Goodrow
716 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 6-1, Botvin Spring 2024 Lid van UMass Dartmouth, Team 6-1, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G1
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 48
Altijd: 643
