Inleiding
This is a guide on how to replace the contact pins inside of the headset.
Wat je nodig hebt
To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
Use the Phillips #0 screw bit to remove the four screws (9.47 mm long) that have been revealed from removing the ear cup. Carefully take off the blue casing to reveal the audio board.
Bijna klaar!
Conclusie
