Ga door naar hoofdinhoud
Turtle Beach Elite 800 Charging Pins on Headset Replacement
Wat je nodig hebt
  1. Turtle Beach Elite 800 Charging Pins on Headset Replacement, Ear Cushion: stap 1, afbeelding 1 van 2 Turtle Beach Elite 800 Charging Pins on Headset Replacement, Ear Cushion: stap 1, afbeelding 2 van 2
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Charging Pins on Headset Replacement, Charging Contact Pins on Headset: stap 2, afbeelding 1 van 2 Turtle Beach Elite 800 Charging Pins on Headset Replacement, Charging Contact Pins on Headset: stap 2, afbeelding 2 van 2
    • Use the Phillips #0 screw bit to remove the four screws (9.47 mm long) that have been revealed from removing the ear cup. Carefully take off the blue casing to reveal the audio board.
  3. Turtle Beach Elite 800 Charging Pins on Headset Replacement: stap 3, afbeelding 1 van 3 Turtle Beach Elite 800 Charging Pins on Headset Replacement: stap 3, afbeelding 2 van 3 Turtle Beach Elite 800 Charging Pins on Headset Replacement: stap 3, afbeelding 3 van 3
    • Use the Phillips #00 screw bit to remove the two screws (7.92 mm long) that are holding the contact pins in place.
    • Then, simply push the pins from the board.
Conclusie
Johnny Lofton
861 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 968
