Ga door naar hoofdinhoud
Turtle Beach Ear Force XO Seven Speaker Cone Replacement
Wat je nodig hebt
  1. Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Ear Pad: stap 1, afbeelding 1 van 2 Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Ear Pad: stap 1, afbeelding 2 van 2
    • Begin by placing your thumb on the plastic edge around the ear pad.
    • Get a good grip around the ear pad and gently separate it from the headset.
    • Apply the same instructions to remove the other foam pad off of the headset.
    • Make sure you continue to gently peel the ear pad from the headset until completely removed.
  2. Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Speaker Cone: stap 3, afbeelding 1 van 2 Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Speaker Cone: stap 3, afbeelding 2 van 2
    • A new speaker cone for these headphones will cost about $8 to $10 from amazon.com.
    • After removing the ear pads, unscrew the four Phillips head screws that hold the front plate on.
    • To avoid losing small screws, place them in a container.
  3. Turtle Beach Ear Force XO Seven Speaker Cone Replacement: stap 4, afbeelding 1 van 2 Turtle Beach Ear Force XO Seven Speaker Cone Replacement: stap 4, afbeelding 2 van 2
    • When removing the speaker cone plate, be careful not to drop it or put stress on the wires as they are very delicate.
    • Remove the speaker cone plate on a flat surface to prevent unnecessary stress on the wires.
    • The speaker cone is attached to the front plate. To replace, unsolder the wires from the two connection points.
  4. Turtle Beach Ear Force XO Seven Speaker Cone Replacement: stap 5, afbeelding 1 van 1
    • Replace the speaker cone carefully in place of the old one.
    • Consider tinning the wires before soldering them on to the new speaker cone.
    • Solder the wires back on to the new speaker cone.
    • Reassemble the front plate.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jacob
166 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-36, Amido Winter 2015 Lid van Cal Poly, Team 17-36, Amido Winter 2015
CPSU-AMIDO-W15S17G36
4 Leden
12 handleidingen geschreven
3 opmerkingen
I couldn't find the speaker cone at amazon. Does anyone have a link?
victorlborges - Antwoord
You need to buy a Broken Headset the use that to replace the speaker.
Andy Millett - Antwoord
Is there anywhere that i can buy replacement swivel part that hold the speaker
Robert bee - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 5,541
