Ga door naar hoofdinhoud
Turtle Beach Ear Force XO Seven Slide Adjustment Replacement
Wat je nodig hebt
  1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: stap 1, afbeelding 1 van 2 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: stap 1, afbeelding 2 van 2
    • Remove the two 1.0 cmTorx T6 screws using the matching Torx T6 screwdriver.
  2. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: stap 2, afbeelding 1 van 2 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: stap 2, afbeelding 2 van 2
    • Insert the spudger into the gap between the leather and plastic.
    • After making sure you have a good grip, use the spudger to pry the two plastic pieces apart.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Nancy Truong
375 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-36, Amido Winter 2015 Lid van Cal Poly, Team 17-36, Amido Winter 2015
CPSU-AMIDO-W15S17G36
4 Leden
12 handleidingen geschreven
7 opmerkingen
What if the plastic part that connects the earphones to the headband breaks and is there a way I can fix or replace that ??
jamesfalduto - Antwoord
I really don't want to buy another turtle beach headset
James did you ever find a solution because I have the same problem
Commandcorps - Antwoord
Same problem here commandcorps.
adampm1 -
Same problem… plastic slide adjustment broke… contacted turtle beach and haven’t heard back… it should be an easy fix but can’t find the parts anywhere thus far…
Jim Davis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 4,313
