Ga door naar hoofdinhoud
Turtle Beach Ear Force XO One Adapter Buttons Replacement
Wat je nodig hebt
  1. Turtle Beach Ear Force XO One Adapter Buttons Replacement, Adapter Buttons: stap 1, afbeelding 1 van 1
    • Using a Philips head screwdriver, unscrew the two screws on the back of the adapter.
    • The recommended screwdriver bit size is a PH 000.
  2. Turtle Beach Ear Force XO One Adapter Buttons Replacement: stap 2, afbeelding 1 van 1
    • Using your hands and/or a prying tool, carefully pry open the adapter.
    • This step may require a bit of force to complete.
    • Be aware that the adapter is held together with clips on the inside at some locations.
    • Do not be alarmed if it makes a snapping sound as it comes apart, this is most likely just the sound of the clips detaching.
  3. Turtle Beach Ear Force XO One Adapter Buttons Replacement: stap 3, afbeelding 1 van 3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: stap 3, afbeelding 2 van 3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: stap 3, afbeelding 3 van 3
    • Now, using the same Philips head screwdriver, unscrew the two screws on either side that hold the circuit board to the adapter case.
    • Once the screws are out, you can remove the circuit board from the casing.
  4. Turtle Beach Ear Force XO One Adapter Buttons Replacement: stap 4, afbeelding 1 van 1
    • Push the rubber piece containing the buttons out of the plastic adapter casing.
    • Then, replace it with a new one.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joseph Lane
128 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-1, Shastany Fall 2015 Lid van UMass Dartmouth, Team 3-1, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G1
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 1,580
