Ga door naar hoofdinhoud
Turtle Beach Ear Force X12 Slide Adjustment Replacement
Wat je nodig hebt
  1. Turtle Beach Ear Force X12 Slide Adjustment Replacement, Slide Adjustment: stap 1, afbeelding 1 van 1
    • Remove the two 1.10 mm screws using the a T3 screwdriver.
  2. Turtle Beach Ear Force X12 Slide Adjustment Replacement: stap 2, afbeelding 1 van 3 Turtle Beach Ear Force X12 Slide Adjustment Replacement: stap 2, afbeelding 2 van 3 Turtle Beach Ear Force X12 Slide Adjustment Replacement: stap 2, afbeelding 3 van 3
    • Insert the plastic opening tool into the gap between the fabric and the plastic.
    • Make sure you have a firm grip, use the plastic opening tool to pry the two plastic pieces apart.
    • Be careful not to crack or brake the plastic pieces.
    • You should have two plastic pieces removed at the end. Replace them with new ones and reassemble.
Conclusie
Katha Patel
218 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G3, Thompson Fall 2017 Lid van USF Tampa, Team S1-G3, Thompson Fall 2017
USFT-THOMPSON-F17S1G3
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 537
