Ga door naar hoofdinhoud
Tungsten E Disassembly
Wat je nodig hebt
  1. Tungsten E Disassembly, Tungsten E Disassembly: stap 1, afbeelding 1 van 2 Tungsten E Disassembly, Tungsten E Disassembly: stap 1, afbeelding 2 van 2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Disassembly: stap 2, afbeelding 1 van 3 Tungsten E Disassembly: stap 2, afbeelding 2 van 3 Tungsten E Disassembly: stap 2, afbeelding 3 van 3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Tungsten E Disassembly: stap 3, afbeelding 1 van 2 Tungsten E Disassembly: stap 3, afbeelding 2 van 2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Disassembly: stap 4, afbeelding 1 van 2 Tungsten E Disassembly: stap 4, afbeelding 2 van 2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Disassembly: stap 5, afbeelding 1 van 3 Tungsten E Disassembly: stap 5, afbeelding 2 van 3 Tungsten E Disassembly: stap 5, afbeelding 3 van 3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Disassembly: stap 6, afbeelding 1 van 1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
Conclusie
Kevin Hom
103 Reputatie
2 handleidingen geschreven
Cal Poly, Team 13-22, Maness Winter 2010 Lid van Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Leden
4 handleidingen geschreven
1Gids Commentaar
How does one unplug the battery?
dlcatftwin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 7,925
