Inleiding
The power cable developed an intermittent fault near where it enters the device so I needed to disassemble it.
Wat je nodig hebt
Only 2 screws for main body case.
The left hand screw was covered by a softish translucent disc (shown in bottom left of photo) - easily removed with a pointy spudger.
Gently work the spudger blade in and depress the 2 marked snap fit clips enough to free the top of the case.
Once the two clips on this side are free you should be able to wiggle the top of the case enough to hinge it open.
Één andere persoon heeft deze handleiding voltooid.
