Ga door naar hoofdinhoud
Tritton Kunai Left Speaker Replacement
Wat je nodig hebt
  1. Tritton Kunai Left Speaker Replacement, Left Speaker: stap 1, afbeelding 1 van 2 Tritton Kunai Left Speaker Replacement, Left Speaker: stap 1, afbeelding 2 van 2
    • Firmly grasp the black ear cushion with one hand and the white speaker frame with the other hand.
    • Forcibly pull the ear cushion and speaker frame in opposite directions, until the right ear cushion separates from the right ear frame.
  2. Tritton Kunai Left Speaker Replacement: stap 2, afbeelding 1 van 2 Tritton Kunai Left Speaker Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 9 mm screws indicated in red with a PH00 screwdriver.
    • Remove the two 7 mm screws indicated in orange with a PH00 screwdriver.
    • Separate the black horseshoe shaped frame from the right speaker frame.
  3. Tritton Kunai Left Speaker Replacement: stap 3, afbeelding 1 van 2 Tritton Kunai Left Speaker Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 7 mm screws indicated in red using a PH00 screwdriver.
    • Separate the black bracket and then the rail adjustment from the right speaker frame.
  4. Tritton Kunai Left Speaker Replacement: stap 4, afbeelding 1 van 2 Tritton Kunai Left Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the six 7 mm screws indicated in red using a PH00 screwdriver.
    • Separate the black speaker console from the right speaker frame.
  5. Tritton Kunai Left Speaker Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the red and white wires from the 16 Ohm speaker.
  6. Tritton Kunai Left Speaker Replacement: stap 6, afbeelding 1 van 1
    • Squeeze the tip of the tweezers into the gap between the speaker and the speaker case.
    • Remove the glue holding the speaker in place by scraping the glue with the tip of the tweezers.
  7. Tritton Kunai Left Speaker Replacement: stap 7, afbeelding 1 van 2 Tritton Kunai Left Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the speaker from its circular shaped slot.
    • Apply glue to the sides of your new 16 Ohm speaker.
  8. Tritton Kunai Left Speaker Replacement: stap 9, afbeelding 1 van 2 Tritton Kunai Left Speaker Replacement: stap 9, afbeelding 2 van 2
    • Insert your new speaker into the circular shaped slot located on the speaker cover.
  9. Tritton Kunai Left Speaker Replacement: stap 10, afbeelding 1 van 1
    • Solder the wires you disconnected from the old speaker to the new speaker. The red wire is to be soldered to the far left terminal, while the white wire is to be soldered to the far right terminal.
    • Here is iFixit's soldering guide.
    • Solder with caution and try not to burn yourself.
Conclusie
To reassemble your device, follow steps 1 through 4 in reverse order.
3 andere personen hebben deze handleiding voltooid.
Elias El Tom
338 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-3, Duarte Spring 2015 Lid van UMass Dartmouth, Team 3-3, Duarte Spring 2015
UMASSD-DUARTE-S15S3G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 1,404
