Ga door naar hoofdinhoud
Trio Stealth Pro 9.7" Rear/Front Camera Replacement
Wat je nodig hebt
  1. Trio Stealth Pro 9.7" Rear/Front Camera Replacement, Rear/Front Camera: stap 1, afbeelding 1 van 1
    • Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
  2. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: stap 2, afbeelding 1 van 2 Trio Stealth Pro 9.7" Rear/Front Camera Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
  3. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: stap 3, afbeelding 1 van 3 Trio Stealth Pro 9.7" Rear/Front Camera Replacement: stap 3, afbeelding 2 van 3 Trio Stealth Pro 9.7" Rear/Front Camera Replacement: stap 3, afbeelding 3 van 3
    • Use plastic opening tool to lift up black clip.
    • Gently pull out flex cable.
  4. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove 3 silver 4 cm Phillips screws holding down black plastic speaker cover.
    • Gently pull up on plastic to uncover clip connected to the camera.
  5. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: stap 5, afbeelding 1 van 2 Trio Stealth Pro 9.7" Rear/Front Camera Replacement: stap 5, afbeelding 2 van 2
    • Use the tweezers and gently lift up on the clip.
    • Remove the front/rear camera.
Conclusie
Edward Insogna
626 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 1-3, Miles Spring 2015 Lid van UMass Dartmouth, Team 1-3, Miles Spring 2015
UMASSD-MILES-S15S1G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 150
