Ga door naar hoofdinhoud
Trio AXS 3G Back Case Replacement
Wat je nodig hebt
  1. Trio AXS 3G Back Case Replacement, Back Case: stap 1, afbeelding 1 van 1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Back Case Replacement: stap 2, afbeelding 1 van 2 Trio AXS 3G Back Case Replacement: stap 2, afbeelding 2 van 2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Back Case Replacement: stap 3, afbeelding 1 van 1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
Conclusie
Javoy Ross
316 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 346
