Ga door naar hoofdinhoud
Tribit XSound Go TS-BTS20 Passive Radiator Replacement
Wat je nodig hebt
  1. Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: stap 1, afbeelding 1 van 2 Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: stap 1, afbeelding 2 van 2
    • Insert a spudger in the seam between the front speaker grill and chassis.
    • Pry around the perimeter until the front grill releases.
    • Remove the front grill.
  2. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: stap 2, afbeelding 1 van 1
    • Unscrew all the screws with the Phillips screwdriver, on the opened panel.
    • Lift off the speaker housing.
  3. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: stap 3, afbeelding 1 van 2 Tribit XSound Go TS-BTS20 Passive Radiator Replacement: stap 3, afbeelding 2 van 2
    • Hold the frame which has the passive radiator in the middle.
  4. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger to push the damaged passive radiator off the frame
  5. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: stap 5, afbeelding 1 van 1
    • Insert the new passive radiator into the frame.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
Conclusie
Hasini Kanuru
271 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 56
