Ga door naar hoofdinhoud
Triace A310 Disk Brake Replacement
Wat je nodig hebt
  1. Triace A310 Disk Brake Replacement, Tire: stap 1, afbeelding 1 van 1
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Disk Brake Replacement: stap 2, afbeelding 1 van 2 Triace A310 Disk Brake Replacement: stap 2, afbeelding 2 van 2
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Disk Brake Replacement: stap 3, afbeelding 1 van 2 Triace A310 Disk Brake Replacement: stap 3, afbeelding 2 van 2
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Disk Brake Replacement, Disk Brake: stap 4, afbeelding 1 van 1
    • Place the tire flat on the ground making sure the disk is facing you.
  5. Triace A310 Disk Brake Replacement: stap 5, afbeelding 1 van 3 Triace A310 Disk Brake Replacement: stap 5, afbeelding 2 van 3 Triace A310 Disk Brake Replacement: stap 5, afbeelding 3 van 3
    • Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
    • Make sure to keep track of all of the removed pieces.
  6. Triace A310 Disk Brake Replacement: stap 6, afbeelding 1 van 2 Triace A310 Disk Brake Replacement: stap 6, afbeelding 2 van 2
    • After all of the screws have been removed, take the disk and pull it away from the tire.
Conclusie
Daniel
222 Reputatie
2 handleidingen geschreven
Cal Poly, Team 1-37, Maness Winter 2014 Lid van Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 588
