Ga door naar hoofdinhoud
Triace A310 Chain Replacement
Wat je nodig hebt
  1. Triace A310 Chain Replacement, Tire: stap 1, afbeelding 1 van 1
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Chain Replacement: stap 2, afbeelding 1 van 2 Triace A310 Chain Replacement: stap 2, afbeelding 2 van 2
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Chain Replacement: stap 3, afbeelding 1 van 2 Triace A310 Chain Replacement: stap 3, afbeelding 2 van 2
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Chain Replacement, Chain: stap 4, afbeelding 1 van 3 Triace A310 Chain Replacement, Chain: stap 4, afbeelding 2 van 3 Triace A310 Chain Replacement, Chain: stap 4, afbeelding 3 van 3
    • Locate the master link along the chain.
    • Note: If the master link matches the one pictured in this step continue with the instructions, if not skip to the next step.
    • With pliers squeeze the two pins together so that the chain comes apart.
  5. Triace A310 Chain Replacement: stap 5, afbeelding 1 van 3 Triace A310 Chain Replacement: stap 5, afbeelding 2 van 3 Triace A310 Chain Replacement: stap 5, afbeelding 3 van 3
    • Note: This step is only for chains with a master link clip.
    • With a plier press the two pins together and remove the clip.
    • Once the clip is removed the chain should easily come apart.
  6. Triace A310 Chain Replacement: stap 6, afbeelding 1 van 1
    • Once the chain is separated, remove it from the bike by pulling one end.
  7. Triace A310 Chain Replacement: stap 7, afbeelding 1 van 3 Triace A310 Chain Replacement: stap 7, afbeelding 2 van 3 Triace A310 Chain Replacement: stap 7, afbeelding 3 van 3
    • With the new chain, place it on the current gear that your bike is in.
    • Note: If you don't know which gear your bike is in place the chain on one of the middle gears.
    • Thread one end of the chain through the derailleur from top to bottom so it is in the shape of a 'S'.
    • Next place the chain on the back gears, making sure that it is threaded through the guide.
  8. Triace A310 Chain Replacement: stap 8, afbeelding 1 van 3 Triace A310 Chain Replacement: stap 8, afbeelding 2 van 3 Triace A310 Chain Replacement: stap 8, afbeelding 3 van 3
    • To reassemble the chain bring both ends of the chain together so that the pins on each one lineup.
    • Grip the chain on both sides of the master link and pull.
  9. Triace A310 Chain Replacement: stap 9, afbeelding 1 van 3 Triace A310 Chain Replacement: stap 9, afbeelding 2 van 3 Triace A310 Chain Replacement: stap 9, afbeelding 3 van 3
    • If your chain does have a master link clip replace the link around the two pins.
    • Use a plier to slide the clip back into place.
Conclusie
Once your chain is back together, you are ready to once again, hit the trails.
Één andere persoon heeft deze handleiding voltooid.
Jacob Rickman
159 Reputatie
1 Handleiding geschreven
Cal Poly, Team 1-37, Maness Winter 2014 Lid van Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 726
