Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unscrew the brake pad cap with a T25 screwdriver bit.
Grab and pull out the spring between the brake pads.
Slide out the back brake pad first. Then slide out the front brake pad.
Slide in the new brake pads with the first going in the front.
Push the spring back into place between the two brake pads so the spring is visible in the hole shown here.
Adjust the red knob as necessary (directions are noted on the knob).
