Ga door naar hoofdinhoud
Triace A310 Brake Cable Replacement
Wat je nodig hebt
  1. Triace A310 Brake Cable Replacement, Brake Cable: stap 1, afbeelding 1 van 2 Triace A310 Brake Cable Replacement, Brake Cable: stap 1, afbeelding 2 van 2
    • WARNING: Be sure to follow each step carefully. Failure to do so may result in serious injury or death.
    • Unscrew the screw holding the brake cable in place with a 5mm allen wrench and pull out the cable.
  2. Triace A310 Brake Cable Replacement: stap 2, afbeelding 1 van 3 Triace A310 Brake Cable Replacement: stap 2, afbeelding 2 van 3 Triace A310 Brake Cable Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the slotted brake cable cap on the rear tire and pull out the cable. Remove the cap from the cable.
  3. Triace A310 Brake Cable Replacement: stap 3, afbeelding 1 van 2 Triace A310 Brake Cable Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the cap next to the brake handle and remove it from the cable.
  4. Triace A310 Brake Cable Replacement: stap 4, afbeelding 1 van 3 Triace A310 Brake Cable Replacement: stap 4, afbeelding 2 van 3 Triace A310 Brake Cable Replacement: stap 4, afbeelding 3 van 3
    • Pull up and out on the cable to remove the barrel nipple (the small cylinder at the end of the cable).
  5. Triace A310 Brake Cable Replacement: stap 5, afbeelding 1 van 3 Triace A310 Brake Cable Replacement: stap 5, afbeelding 2 van 3 Triace A310 Brake Cable Replacement: stap 5, afbeelding 3 van 3
    • Unscrew the bracket located on the front tire with a 3mm allen wrench.
    • Rotate the bracket 90 degrees or until the opening is large enough for the cable. Remove the cable.
    • Note that if removing cable for rear brake, rather than unscrewing a bracket, you will unclip several "spring" clips. Keep track of clips.
    • Test your brakes in a low-speed environment to ensure that they work.
Conclusie
To place the new cable, follow these instructions in reverse order.
Ben Hartinger
340 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-37, Maness Winter 2014 Lid van Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 327
