Ga door naar hoofdinhoud
Trek 820 Tail Light Mounting Bracket Replacement
Wat je nodig hebt
  1. Trek 820 Tail Light Mounting Bracket Replacement, Tail Light Mounting Bracket: stap 1, afbeelding 1 van 1
    • Obtain one tail light mounting bracket and one screw as shown in the picture.
    • The screw should be removed from the mounting bracket.
  2. Trek 820 Tail Light Mounting Bracket Replacement: stap 2, afbeelding 1 van 1
    • Clean the bicycle seat post and mounting bracket.
    • Wrap the mounting bracket strap around the seat post.
    • Verify the larger piece rests towards the tail end aligned with the tires.
    • Verify the bracket's screw hole is on the right side of the bicycle.
  3. Trek 820 Tail Light Mounting Bracket Replacement: stap 3, afbeelding 1 van 2 Trek 820 Tail Light Mounting Bracket Replacement: stap 3, afbeelding 2 van 2
    • Locate the slot on the bracket where the strap will be inserted.
    • Insert the strap into the slot.
    • Tighten the strap just enough to keep the bracket in place.
  4. Trek 820 Tail Light Mounting Bracket Replacement: stap 4, afbeelding 1 van 2 Trek 820 Tail Light Mounting Bracket Replacement: stap 4, afbeelding 2 van 2
    • Insert the screw into the bracket screw hole.
    • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
Conclusie
Kaveh Karimiyanha
813 Reputatie
7 handleidingen geschreven
Cal Poly, Team 1-1, Propen Fall 2012 Lid van Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,117
